offroadmediagroup
#1 Posted : Tuesday, October 6, 2026 8:04:16 AM(UTC)
offroadmediagroup
Please consider adding DB indicators on audio meters. Additionally a flag for selecting DB and LUFS both on inputs and outputs.
kross
#2 Posted : Tuesday, October 6, 2026 11:58:17 AM(UTC)
kross
Was thanked: 46 time(s) in 45 post(s)
It has dBFS on the main audio settings dialog, but I agree it would be nice if it had the readings on the main audio meters as well (although UI space is limited).
As for LUFS, I also would like something native to vMix. However, since that's something that's integrated over time, with different options available, I don't mind that they leave it to the user to install a loudness meter of their choice as a VST plugin. In my case, I use Youlean Loudness Meter (I am in no way affiliated with them), but I'm sure there are others available that work just as well or ever better.
One limitation of this approach is, the VST gets the audio pre-fader, so any loudness adjustments you make in the audio settings won't actually be reflected in the loudness meter VST. The way I work around this is, I just install a single VST on the Master audio channel, and just have a global combined LUFS meter. This does pick up any fader changes made on individual audio inputs. It works pretty well, especially since my main use case is balancing audio levels of multiple commentators, and having them show up in the same meter actually works for me. Of course YMMV.
Mathias Schneider
#3 Posted : Thursday, October 8, 2026 1:19:34 AM(UTC)
Mathias Schneider
Germany
Thanks for this thread, it was the push to build something I had on the list for a while.
kross is right about the VST position: a plugin inside vMix sits pre-fader, so it never shows what actually leaves the machine. The only way to read the real program loudness is to measure after vMix, on the signal the output device receives.
That is where MixDesk X sits, so I added LUFS metering to it (ITU BS.1770 / EBU R128): every input and output strip now has a PEAK | LUFS switch. LUFS mode shows Momentary as the bar, Short-term as the big number, Integrated, LRA and True Peak (4x oversampled), with a selectable target (-23, -24, -20, -18, -16, -14). The bar goes green within +/-1 LU of the target, true peak turns red above -1 dBTP. Reset for the start of the show, mode and target are saved in the preset. Plus peak hold on all meters, including the RTA.
Setup for vMix: route the vMix master to a virtual audio device and take that as an input in MixDesk X on the same PC. You then read the real program loudness, post every fader, and you can still feed the hall from MixDesk X with its own EQ and limiter. On Windows one stereo loop is free with VB-Cable; if you need several loops at once, the paid cable variants are the only thing in this chain that costs anything, MixDesk X itself is free.
