Joined: 9/7/2024(UTC) Posts: 64  Location: The Great PNW Was thanked: 10 time(s) in 9 post(s)
There is visual disparity between buses and PGM meters. Audio is in sync, but the meters are not. This drives engineers nuts! I can only currently observe the bus/PGM dependency, not seeing the same issue between inputs and buses.
Please consider revisiting the UI of meters and make sure they are all in sync.
 1 user thanked offroadmediagroup for this useful post.
Joined: 11/14/2012(UTC) Posts: 414  Location: Finland Thanks: 272 times Was thanked: 40 time(s) in 38 post(s)
+1
Yes, the meters are outdated and also miss audio peaks/beats due meters low update rate.
At least vMix should internally watch the signals more intensively and buffer/ "super sample" audio for visuals, so peaks would be dispalyed even if the update rate for gui elements would be at lower rate. And all of this should of course be synced together.
This current "vMix will miss a beat" behaviour can easily be demonstrated with the built in "Sample input" -input.
Joined: 10/29/2019(UTC) Posts: 105  Location: Syracuse Thanks: 11 times Was thanked: 5 time(s) in 4 post(s)
I imagine updating all of the input & mixer meters on larger setups, even at 24 updates / second, is a bit of a challenge while keeping CPU low. I assume they aren't updating meters on hidden tabs, but still.
At mimimum, though, the master bus metering should have a priority, high rate update thread. The master meter is also in dire need of a UI update with a visible scale, RMS bars, independent peak lines, and maybe clip indicators with hold.
