Originally Posted by: Pierre Saleh Kandolo  Hi everyone, vMix has added the number of overlays, but UTC is still stuck at 4 despite the latest update... Or is there a version already released that I don't have, like the screenshots? Thanks in advance for your help and guidance.  Capture d'ecran 2026-04-03 183701.png (285kb) downloaded 183 time(s). You can change it in code tab
Thanks: 74 times Was thanked: 7 time(s) in 7 post(s)
Hello everyone, hello @elgarf! I did all the updates to UTC, and in the latest version from 25.04.2026 I noticed that the button function disappeared, only Button + remained. Ok, but the only problem I noticed is that Button + no longer has the "timer" function, which I consider a drawback of UTC LE.I solved it with the 'delay' function
Okay, I'm probably overlooking something here. How can I toggle an image on and off in the new UTC version? I'm having a hard time finding that function.
Joined: 9/16/2026(UTC) Posts: 2   Location: Lubelskie
I downloaded the updated version of UTC, but I couldn't find the “TransitionMix” command. Was it removed? Or is there another way to configure it?
