offroadmediagroup
#1 Posted : Thursday, September 17, 2026 11:33:38 PM(UTC)
offroadmediagroup
Triggers can appear many times to be instant... but they are not. They still are a stepped sequence. This leads to situations with dual-format coordination where you're triggering two different mixes, or two playlists, or anything where there is multiple calls that need to be synchronized that are just not possible.
Please consider adding functionality that allows for triggers to be synchronized. This could be a check box in the triggers that enables this, or a new "mode" for a trigger... doesn't really matter. As long as we can call or enact a set of triggers in sync with each other. This should also be exposed to the API so that calls to the system can also be synchronized.
