Does HD license support Countdown to Time
Joined: 8/29/2020(UTC) Posts: 8   Location: Arizona Thanks: 1 times
I’m running vMix 29.0.0.49 HD. This is what I want to accomplish; when I arrive at Church on Sunday mornings between 07:30 to 07:40, I want to start countdown to 08:55 which will trigger slides. 1st slide starts streaming, with 40 secs of background music, text states service start time 09:00 upon completion fades to 2nd slide. The 2nd slide starts recording, with 30 secs of background music, text states the day of the church calendar year, upon completion fades to 3rd slide. 3rd slide has 20 secs of background music, text states name of Pastor who is officiating. Upon completion it fades to 1st PTZ camera. From then it is manual intervention during the church service. At the end of the service, I fade to the finishing slide which stops the Recording, FTB and stops Streaming. • I’ve added Title, GT Timer, Timer the Middle-R.gtzip. It is input #1 • I selected the Title, Opened Title Editor, Expanded Clocks, Selected Countdown to Time. • Selected, {0:3:00:00 PM|HH:mm:ss} I Added the seconds • I’ve set the trigger to; On Countdown Complete, fade to Input # 2, which is my slide # 1. It counted down to 00:00:00. The trigger didn’t fire • To test, I’ve changed the target time. I’m wondering if my HD license will allow me to do this operation? I’ve sent email to support Sunday night 8/31/26. So far, no response from vMix support. If I’m doing something wrong, please identify area.
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
OnCountdownCompleted triggers only work with a "real" Countdown timer, not with the Countdow to Time function. You can set it up on the settings button in the Title Editor.
Joined: 11/23/2020(UTC) Posts: 252  Location: Wichita Thanks: 14 times Was thanked: 32 time(s) in 28 post(s)
You need the 4K version minimum to have scripting available. Then you can use the script I posted in the scripting for Dummies thread that does a countdown to a time.
