Feature Requests
Fade on playlist and layers & Sys info input for multiview
Joined: 11/27/2020(UTC) Posts: 4  Location: Cornllà del Terri Thanks: 1 times
Hi, I been using Vmix for a while, mainly as streaming and content player at congresses, and I have ended with some suggestions for addons on your awsome sofware, most of them have workarounds to endup with similar utilities but, from my point of view would be nice to have it straight.
1- optional fade trasintion on lists 2-one configurable input with system info to put it on the multiview (cpu/gpu/Loar, recording/streaming/calls/Zoom status, counters, timers, avlaliable free space on hrdisks.... you name it) 3- allow layers to apear and desapear by fade ( it will be nice to have a multiview layer toggle on/off by fade (even 500ms fixed)
hope we can se some of them soon, best and congrats for your work
Joined: 4/23/2017(UTC) Posts: 1,494  Location: Germany Thanks: 3 times Was thanked: 199 time(s) in 179 post(s)
Add the following shortcuts to the vmix 30 API:
SetLayer1Border
SetLayer1BorderColor
SetLayer1BorderThickness
SetLayer1BorderRadius You can also add shortcuts to load virtual folder XML files using the API.
Joined: 8/2/2013(UTC) Posts: 1,100   Location: Fairhope, Alabama USA Thanks: 592 times Was thanked: 204 time(s) in 170 post(s)
Originally Posted by: emet  Hi, I been using Vmix for a while, mainly as streaming and content player at congresses, and I have ended with some suggestions for addons on your awsome sofware, most of them have workarounds to endup with similar utilities but, from my point of view would be nice to have it straight.
Good ideas, but they will be lost with your non-descriptive title. - Tom
Feature Requests
