According to the Knowledge Base here: https://www.vmix.com/kno...m-breakout-rooms-in-vmixThe latest vMix Zoom Plugin should be able to join a breakout room when assigned by a host. I use the workplace app on a seperate laptop and assign vMix to a breakout. Unfortunately the vMix Zoom plugin does not move to the breakout and stays in the main zoom session. My plugin version is 7.0.1.35140 What am I doing wrong?
As added to the Knowledge Base: it was required to enable "Automatically move all assigned participants into breakout rooms" in zoom. Now it works as expected.
Just to jump onto this, I am running the latest recommended Zoom Plugin 6.0.11 on VMIX 29.0.0.49 with a 4K license. I have the plugin configured per the knowledge base article to recording and have enabled automatic moving to breakout rooms, however while I can see the VMIX endpoint has moved. It does not start sending/ receiving video when in a Breakout room. The VMIX software can see the caller names however on the host Zoom computer it shows the VMIX caller as having it's camera switched off and I do not get a prompt about recording.
Any assistant would be very helpful.
Just to immediately edit my own comment. The order of operations is quite fiddly. You need to join the meeting without any breakout rooms running so you can get the recording warning popup on the VMIX computer. Then once that is accepted you can start the breakout rooms and switch to the room.
