Abayomitsn
#1 Posted : Sunday, August 23, 2026 11:07:03 PM(UTC)
Abayomitsn
Canada
I can see the ndi input from easy worship on vmix but it's black. I have tried 3 different ndi inputs and they are black
mavik
#2 Posted : Monday, August 24, 2026 4:15:26 AM(UTC)
mavik
NDI announcement is done over mDNS. That part seems to work. A black image is usually when there is a network issue.
First tool to narrow it down is to use NDI Studio Monitor and see if you get a picture. That is the reference.
If Studio Monitor is black as well you have to share more details of your signal path, switches, routers, NICs, network in general. The more precise you be the better one can guide you and help. Try to change the computer or the source to see if there is a general issue and in what direction to focus the search.
kross
#3 Posted : Tuesday, September 8, 2026 2:22:04 PM(UTC)
kross
Was thanked: 46 time(s) in 45 post(s)
I've had this happen to me several times. NDI feeds show up perfectly in Studio Monitor. It happens when starting vMix or reloading a project. I will sometimes get nothing but black for all of my NDI sources (I have 4). If I restart vMix enough times it finally works, and then everything is fine for the rest of the session. It doesn't happen every time, but it's an annoyance when it does.
thanks 1 user thanked kross for this useful post.
NicholasLowFK on 9/11/2026(UTC)
mavik
#4 Posted : Tuesday, September 8, 2026 6:30:42 PM(UTC)
mavik
Have you tried removing the NDI source and add the input again or even start a new session. Is the NDI input working there. If, it might be a corrupted session file. You could also open the session in an editor and check for something strange in there. It has xml structure.
NicholasLowFK
#5 Posted : Friday, September 11, 2026 11:03:36 PM(UTC)
NicholasLowFK
Malaysia
vMix NDI Input freezes after ~4 hours – source remains visible, but new NDI input is blank
I am experiencing a recurring NDI issue with vMix and an OBSBOT Tail 2 PTZ camera.
The problem has happened several times, and the behavior is very similar each time.
### System / Setup
* vMix: vMix 29.0.0.48
* Camera: OBSBOT Tail 2
* NDI: Camera is outputting NDI over the LAN
* Resolution: 1080p59.94
* Network: Gigabit Ethernet
* Windows PC
* CPU: Intel i7-14700K
* RAM: 64 GB DDR4-3200
* GPU: NVIDIA RTX 5070 TI
* vMix is running continuously for several hours.
### The problem
After approximately **4 hours of continuous operation**, one of the OBSBOT NDI inputs in vMix suddenly freezes.
The video freezes on the **last received frame**.
vMix itself does NOT freeze. The vMix interface remains responsive and I can continue operating the other inputs.
The OBSBOT camera itself also appears to continue working.
### What I found when the problem occurs
The important part is that vMix can still **see/discover the OBSBOT NDI source**.
However:
1. The existing NDI input remains frozen on the last frame.
2. Resetting the existing input does not restore the video.
3. Deleting the input and creating a **new NDI input using the same OBSBOT NDI source** results in a **blank screen**.
4. The source is still visible/selectable in the NDI source list.
5. So vMix can discover the NDI source, but it cannot display/receive new video frames from it.
At the same time, I can still use **NDI Studio Monitor to view the same OBSBOT NDI source**, so the camera appears to still be transmitting NDI correctly.
The behavior is essentially:
```text
OBSBOT Tail 2
+---- NDI Studio Monitor -> VIDEO OK
+---- vMix
+---- Existing Input -> LAST FRAME FROZEN
+---- New NDI Input -> BLANK SCREEN
### This has happened multiple times
This is not a one-time occurrence. I have experienced the same behavior several times, generally after the camera/vMix setup has been running for around **4 hours**.
Because the source remains visible in vMix but the video cannot be received even by a newly created NDI input, I am wondering whether the problem could be related to the **vMix NDI receiving/decoding subsystem**, NDI runtime, or a resource issue that develops during long-running sessions.
### Memory usage
I have also observed high system memory usage during some sessions.
At one point:
* System RAM usage reached approximately **97%**
* vMix was using approximately **22 GB RAM**
I am not yet certain whether this is related to the NDI failure, but I am mentioning it because the failure appears after several hours of continuous operation.
### Things I have already checked
* vMix remains responsive when the NDI video freezes.
* Resetting the existing NDI input does not fix it.
* Creating a new NDI input using the same source results in a blank screen.(Source is viewable until you restart vmix)
* The OBSBOT NDI source remains visible/selectable in vMix.
* NDI Studio Monitor can still receive/view the same OBSBOT source when the vMix input is stuck.
I have also seen some unrelated Windows Event Viewer entries involving Intel DSA, DPTF and VBScript, but I do not currently have evidence that these are related to the NDI issue.
### My main questions
1. Does vMix use a persistent NDI receiver/decoder instance that could become stuck after several hours?
2. Is there a way to completely restart/reinitialize the NDI receiving subsystem inside vMix without restarting vMix?
3. Could high memory usage cause this type of behavior where NDI discovery still works but video reception/decoding stops?
4. Are there any known issues with long-running OBSBOT Tail 2 NDI sources in vMix?
5. Is there any vMix/NDI diagnostic log that I can collect when this happens?
I would appreciate any advice on how to diagnose this further.
Thanks!
kross
#6 Posted : Saturday, September 12, 2026 7:16:41 AM(UTC)
kross
Hmm, that's a little different than my experience. In my experience, once the cameras are running, they stay running. I run all-day events, so they are running for a lot more than 4 hours. I even left it running for 48 hours, all the camera feeds were fine. For me, the issue was, if for some reason I needed to restart vMix (usually at the start of the day of a multi-day event), upon restart all the NDI feeds would be black. Restarting again usually cleared it up. And as I said, once it's running, it stays running.
kross
#7 Posted : Saturday, September 12, 2026 7:19:19 AM(UTC)
kross
Oh I forgot to mention, I run a mix of vendors for the NDI streams. A few BirdDog X1 PTZ cameras, as well as some Lumix mirrorless cameras with Zowiebox HDMI-to-NDI encoders. 5 cameras in total, two brands of NDI encoder.
NicholasLowFK
#8 Posted : Tuesday, September 15, 2026 1:57:59 PM(UTC)
NicholasLowFK
Malaysia
hi, i removed the previous source and add it again, but no luck, it appears blank thereafter. it will only back to normal upon restarting vmix
mavik
#9 Posted : Tuesday, September 15, 2026 11:53:57 PM(UTC)
mavik
Best is to try the NDI Analyzer https://ndi.video/tools/analysis/ and report what it says.
Guest (7)
