tripsi
#1 Posted : Friday, August 28, 2026 8:49:16 PM(UTC)
tripsi
Would it be possible to fix the JSON binding for colors? Currently, colors don't link automatically by box name like text and images do, requiring manual selection from the list every time.
#2 Posted : Friday, August 28, 2026 9:22:16 PM(UTC)
Need to be a bit more specific:
How is the color precisely specified in your json data?
Color for what ? Text or shape ?
if for shape is its data unchecked for hidden? (gt title designer)
tripsi
#3 Posted : Saturday, August 29, 2026 12:34:51 AM(UTC)
tripsi
Here:
its boxes / shapes
JSON:
"PA_5_Col": "#FF6F00FF",
"PA_10_Col": "#FF6F00FF",
"PA_15_Col": "#FF6F00FF",
"PA_20_Col": "#FF6F00FF",
"PA_25_Col": "#FF6F00FF",
"PA_30_Col": "#FF6F00FF",
"PA_35_Col": "#FF6F00FF",
"PA_40_Col": "#FF6F00FF",
"PA_45_Col": "#FF6F00FF",
"PA_50_Col": "#FF6F00FF",
"PA_55_Col": "#FF000000",
"PA_60_Col": "#FF000000",
"PA_65_Col": "#FF000000",
"PA_70_Col": "#FF000000",
"PA_75_Col": "#FF000000",
"PA_80_Col": "#FF000000",
"PA_85_Col": "#FF000000",
"PA_90_Col": "#FF000000",
"PA_95_Col": "#FF000000",
"PA_100_Col": "#FF000000",
"PB_5_Col": "#FF6F00FF",
"PB_10_Col": "#FF6F00FF",
"PB_15_Col": "#FF6F00FF",
"PB_20_Col": "#FF6F00FF",
"PB_25_Col": "#FF6F00FF",
"PB_30_Col": "#FF6F00FF",
"PB_35_Col": "#FF6F00FF",
"PB_40_Col": "#FF6F00FF",
"PB_45_Col": "#FF6F00FF",
"PB_50_Col": "#FF6F00FF",
"PB_55_Col": "#FF000000",
"PB_60_Col": "#FF000000",
"PB_65_Col": "#FF000000",
"PB_70_Col": "#FF000000",
"PB_75_Col": "#FF000000",
"PB_80_Col": "#FF000000",
"PB_85_Col": "#FF000000",
"PB_90_Col": "#FF000000",
"PB_95_Col": "#FF000000",
"PB_100_Col": "#FF000000",
vmix:
screenshot from vmix
#4 Posted : Saturday, August 29, 2026 2:30:47 AM(UTC)
Json data needs to be an object array
tripsi
#5 Posted : Saturday, September 5, 2026 12:50:42 AM(UTC)
tripsi
I dont understand. I using json same for text, gfx, all and everything are worked, and for colors you need special object array?
I put there only that color section, Jason start like this
vmix_tournament.zip (4kb) downloaded 3 time(s).
"T_Name": "Onslaught Legends Series - Season 7",
"T_Logo": "X:\\PROJECTS\\OLS\\!STREAM\\Anims\\logoOLS\\logo_OLS_00000.png",
tripsi
#6 Posted : Saturday, September 5, 2026 2:22:21 AM(UTC)
tripsi
ahaaaa.. so fixed
Box name is PA_25_Col
but in Json you need export PA_25_Col.Fill.Color
now its works
#7 Posted : Saturday, September 5, 2026 2:29:01 AM(UTC)
your json is fine
you are not making the right connection:
if it is to change say a rectangle's color it has to be set unhidden in the designer! .
if you want the datasource connection to be automatic you must name the rectangle the same name as given in the json
#8 Posted : Saturday, September 5, 2026 2:31:15 AM(UTC)
ahaaaa.. so fixed
now its works
Only if you want it to be automaticly set (you can do a manual column selection regardless of name)
