Changing Inputs on Triggers Via Scripts
Hello!
Has anyone had success switching inputs within triggers?
Use case: I have a show that needs to switch bugs after an animation. The bugs I use are turned on via triggers (turns on overlay 1 with input 9 on transition in), and I would like to be able to switch the input set to overlay 1 via a script; this way the functionality would remain with the correct bug after the animation.
I can't seem to find a way to alter triggers this way, after doing some research. Does anyone have a way to do this via scripting, or any ideas how I could achieve this?
Thanks!
Use dynamicinputx instead of specific input in the trigger Set/Change dynamicinputx to the input you want
