TL68
#1 Posted : Wednesday, July 8, 2026 7:13:25 PM(UTC)
TL68
Sweden
Hi!
I just discovered that vMix Streaming/SRT inputs does not handle incoming SRT streams in vertical format well. The image is stretched and no aspect ration setting on the input helps.
The problem occurs on both 720x1280 and 1080x1920 incoming streams.
vMix preset is set for vertical.
The streaming application is Haivision Mojopro via Haivision streamhub.
The vertical stream work as it should in other circumstances, if I for example fetch them with VLC player or push them direct to RTMP in our OVP bypassing vMix.
Workaround in vMix seems to be to set Zoom X on the input to 0.425 which gives the correct aspect ratio on the image.
Maybe this can make do as a solution but I am a bit worried this will increase processor load and/or increase risk of other bad effects.
Or should I not worry about this at all?
Thanks in advance for input!
FYI I have registered a support ticket with vMix support regarding this.
sinc747
#2 Posted : Saturday, August 8, 2026 7:20:18 AM(UTC)
sinc747
Was thanked: 204 time(s) in 170 post(s)
Originally Posted by: TL68 Go to Quoted Post
Hi!
Test it and see. Set up the SRT input with no changes and measure CPU use, then make the change and measure. Love to here your results!
- Tom
TL68
#3 Posted : Monday, August 17, 2026 6:09:16 PM(UTC)
TL68
Sweden
Hi!
- Tom
Hi!
I could not see any impact on the CPU load in windows. Also vMix support has verified that this should not risk any bad effects. So hopefully my worries were misplaced.
