Joined: 3/30/2023(UTC) Posts: 125  Location: Chicago Thanks: 11 times Was thanked: 5 time(s) in 4 post(s)
Suddenlly, Zoom calls have the remote participant doubled up on audio sent out from vMix Zoom source.
We found that it can be fixed through a workaround. You need to go into the App Volume Mixer and mute the Zoom applet. This can only be done once you've connected to a meeting. If not, as noted, doubled audio and one of those double audio channels is direct from Zoom to the output, bypassing the vMix's Zoom channel mixer settings (and mute).
Happening on multiple systems. vMix version 29.0.0.48
I'd post an image of the app volume mixer settings but this forum requires it to be hosted somewhere (not just an upload).
Has anyone had this issue yet? It seems to have started in the last day or two.
Thank you,
Fritz Golman RadioDNA
