Luis70
#1 Posted : Tuesday, July 21, 2026 4:34:11 AM(UTC)
Luis70
Grenada
Hi everyone, has anyone tried VDO.Ninja with vMix...it seems to be a great app
knbPixels
#2 Posted : Wednesday, July 22, 2026 4:07:30 AM(UTC)
knbPixels
We use it almost every day to get around the limited number of shares in Zoom. Only drawback is on some systems it seems to tax the cpu too much. There are other users that the sharing doesn't work for them for some reason. We don't use it for cameras or audio.
AlthalusAvan
#3 Posted : Friday, August 7, 2026 6:58:13 AM(UTC)
AlthalusAvan
I just recently used VDO Ninja for a show with 11 guests (plus 3 screenshares). One thing to note is that if you're sending a return feed using one of the vMix virtual webcam outputs, each feed (one per guest) is encoded separately. I didn't realise this until we were already into the show - none of our tests had more than 3-4 guests on. Thankfully my PC was able to handle it, but it had me pushed to nearly 100% CPU usage at times (on a 9800X3D).
Outside of that, it worked really well for us. Some guests who were screensharing had to open a second tab to get that to work, but once they did it was fine. If you're not dialling in a silly number of guests it's definitely a great option.
AngusFindlay
#4 Posted : Friday, August 7, 2026 11:07:34 PM(UTC)
AngusFindlay
I've used it a fair bit as well, for various reasons - Content sharing, overflow room feeds, and occasionally, bringing in extra cameras that don't need to be super low latency.
ThommiTechnik
#5 Posted : Saturday, August 8, 2026 5:22:40 AM(UTC)
ThommiTechnik
Switzerland
Was thanked: 8 time(s) in 7 post(s)
For this, wie have the Meshcast-Option. Use it on sender-site, and you‘re free of hazzles. Downside: will not work, if you‘re using multiple rooms, because of different intercoms, mix-minus, etc.
thanks 1 user thanked ThommiTechnik for this useful post.
AlthalusAvan on 8/10/2026(UTC)
