Instant Replay
The intro stinger doesn't play to the end.
Hi everyone, I need to use a stinger for replay transitions. The stinger lasts 30 frames, and the cut point is set to frame 18. The IN STINGER animation ends at the cut point and doesn't transition smoothly; it cuts off exactly when the replay starts. I’ve tried using both a .mov file and PNG sequences and it's all the same. The OUT STINGER animation plays perfectly. On two vmix machines it's the same situation. I have updated Vmix to the last version. What I'm doing wrong?
Please help.
Thanks: 64 times Was thanked: 160 time(s) in 144 post(s)
Do you have a trigger with the function "OverlayInputAllOff" on the replay input? It will also be applied to stingers, because technically they are overlays.
No I haven't. This is a scenario where I launch a new project without any additional settings—I just drop in a Stinger Input.
Instant Replay
