Joined: 11/27/2020(UTC) Posts: 4  Location: Cornllà del Terri Thanks: 1 times
Hi, I been using Vmix for a while, mainly as streaming and content player at congresses, and I have ended with some suggestions for addons on your awsome sofware, most of them have workarounds to endup with similar utilities but, from my point of view would be nice to have it straight.
1- optional fade trasintion on lists 2-one configurable input with system info to put it on the multiview (cpu/gpu/Loar, recording/streaming/calls/Zoom status, counters, timers, avlaliable free space on hrdisks.... you name it) 3- allow layers to apear and desapear by fade ( it will be nice to have a multiview layer toggle on/off by fade (even 500ms fixed)
hope we can se some of them soon, best and congrats for your work
Joined: 4/23/2017(UTC) Posts: 1,487  Location: Germany Thanks: 3 times Was thanked: 197 time(s) in 177 post(s)
Add the following shortcuts to the vmix 30 API:
SetLayer1Border
SetLayer1BorderColor
SetLayer1BorderThickness
SetLayer1BorderRadius You can also add shortcuts to load virtual folder XML files using the API.
