Have an activator to post the current setting of gain to a midi device, just as InputVolume is giving the value of current fader position an eg InputGain may give the current level of gain. Useful when you have rotary knobs with LEDs (eg. Behringer X-touch) on the gain and you need to know the current gain settings without opening the audio settings in the vMix software.
+1 on this one, it's the one thing I'm missing to complete my setup on my XTouch Compact and seems like a pretty glaring omission to have the ability to add this as a shortcut, but not have access to it from an activator to get the setting back onto the rotary encoder display on the XTouch. When I load a saved show, everything syncs up on the XTouch, except for gain so then I have to go through, check the gain on each input and then manually set the XTouch to that level. Not something that gets messed with frequently, but is a bit of a pain. This post asking for this feature is 2 years old, and there's another from 5 years ago asking for it https://forums.vmix.com/...ortcuts-and-Activatiors, unless InputAudio is dual purpose and can report out Gain in addition to On/Off (which I haven't tried yet, but isn't in the documentation anywhere and I'm guessing is not the case) Thanks.
Joined: 7/4/2021(UTC) Posts: 408  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
Joined: 7/27/2022(UTC) Posts: 31  Thanks: 11 times Was thanked: 2 time(s) in 2 post(s)
The X-Touch Compact will actually run the LEDs as you turn the knobs, however the issue is how you get those in-sync with the gain setting when you first load up a saved Preset. If you have a version of vMix that allows you to use the Scripting, I'd got a simple script you can run to sync the gain settings out to the X-Touch Compact. The Channels multi-dim array contains the channel number of the control you want to set, and the name of the audio channel that you're wanting to sync the gain to. There might be a better way to just take a list of names and then query the channel from the settings XML file, but this works and gets be where I needed. Quote:'====================================== ' Sync Gains Script '====================================== ' Name of each Input to get Gain value for Dim Channels(,) As String = New String(,) {{"10", "Pulpit"}, {"11", "Spanish"}, {"12", "Wireless"}, {"13", "Choir"}, {"14", "Organ"}, {"15", "Piano"}, {"16", "Congregation"}, {"17", "Inst. - Rostrum"}} '{"??", "Inst. - Piano"}
'State variables Dim state as new system.xml.xmldocument Dim CurrentGain As Double Dim SetLED As Double
Console.WriteLine("Getting Gain(s)")
'=========Setup Midi Control======= 'Launch an application Dim ExtApp As New ProcessStartInfo ExtApp.FileName = "C:\Users\samuel\Downloads\sendmidi-windows-1.2.1\sendmidi.exe" ExtApp.UseShellExecute = True ExtApp.WindowStyle = ProcessWindowStyle.Hidden
'=========Get Current Volume======== 'Current status state.loadxml(API.XML())
Dim channel As Integer For channel = 0 To Channels.GetUpperBound(0) Dim Name As String = Channels(channel, 1) Dim MIDICh As String = Channels(channel, 0) Console.WriteLine(Name) CurrentGain = (state.SelectSingleNode("//input[@title='" & Name & "']/@gainDb").Value) Console.WriteLine(Name + " gain is set to : " + CurrentGain.ToString() + "dB") SetLED = CurrentGain / 24 * 127 ExtApp.Arguments = "dev ""X-TOUCH COMPACT SendMIDI"" cc " & MIDICh & " " & SetLED.ToString() Dim proc As Process = Process.Start(ExtApp) Next
'Console.WriteLine(state.OuterXml)
Joined: 8/6/2023(UTC) Posts: 11  Location: Germasogeia
Yes, I still need it.
I can see input volum on screen, but don't know what gain is (
