Feature Requests
Comprehensive Feature Requests for Future vMix Releases (e.g., vMix 30)
Comprehensive Feature Requests for Future vMix Releases (e.g., vMix 30) 1. Pause/Resume Recording Button (Your Suggestion) Add a dedicated "Pause" button next to the Record button. This allows operators to temporarily pause recording during breaks, producing a single, continuous output file and saving significant post-production editing time.
2. Official vMix Local Companion App (Mobile Cam & Mic over LAN) (Your Suggestion) A dedicated mobile app to seamlessly stream a smartphone's camera and microphone as a direct, stable input over local Wi-Fi (similar to Iriun/NDI). It should feature ultra-low latency and allow the director to remotely control camera settings (Focus, Flash, Exposure) directly from vMix.
3. Multi-Segment Trimming (Multiple Mark In / Mark Out) (Your Suggestion) Allow defining multiple sub-clips (multiple Mark In/Out points) within a single video input instead of being restricted to only one segment. Includes a "Playlist Mode" to play these segments sequentially, keeping the interface clean and organized.
4. Built-in AI-Powered Tools Integrate native AI features: AI Background Removal (chromakey-less background extraction), AI Noise Canceling/De-reverb for audio inputs, and Live Auto-Captioning to generate real-time subtitles as GT Titles.
5. Advanced SRT & Multi-PC Workflow Optimization Introduce Dynamic SRT Patching for easy multi-PC streaming setups, combined with automatic audio-video synchronization (Auto-Sync Latency) to seamlessly align feeds between multiple streaming computers.
6. Quick Stinger Creator & 3D Transitions A simplified, built-in tool to quickly create custom stinger transitions by combining video overlays and audio while automatically calculating the cut point. Also, introduce modern 3D/volumetric transitions.
7. vMix Call Upgrades (4K Support & Virtual Green Room) Support for 4K resolution in vMix Call utilizing the highly efficient AV1 codec, alongside a dedicated interactive "Green Room" where the director can prep guests behind the scenes before bringing them live.
8. Project Packaging & Advanced System Diagnostics Enable archiving/exporting an entire project into a single, consolidated, and encrypted package (including all media assets and titles). Additionally, integrate a detailed Resource Monitor to instantly identify bottlenecks (GPU, CPU, Drive speed, thermal throttling).
it would also be good if:-
has a talkback feature
#1. Use a native editor like VideoReDo. Then it's more a copy job. #2. Take a look into SRT #3. like it #4. You could add these externally. I would love to see vMix stays with the roots. And doesn't waste resources. #5. very good. Thanks #6. like it #7. I would love to see 4k and the greenroom. Although I believe it's not coming. #8. good idea
Feature Requests
