Wrighty
#1 Posted : Wednesday, July 15, 2026 9:28:42 PM(UTC)
Wrighty
vMix is an incredible piece of software, but could I suggest / request two small improvements to vMix's audio metering, please?
1. Add a dB scale to the main master meter and ideally to the meters on the inputs and outputs in the Audio Mixer panel. The text could be on top of the bar graph if there's a lack of space alongside.
2. Add compressor gain reduction meters somewhere... Ideally next to the level meters in the respective inputs/outputs in the Audio Mixer panel (with a red bar graph starting at the top), but if there's not enough space there, you could put it in the compressor settings window. As a sound engineer, it's useful to see how hard you're hitting the compressor.
Thank you :)
