OscarE
#1 Posted : Monday, December 15, 2025 8:06:18 PM(UTC)
OscarE
Sweden
Has anyone managed to integrate chat messages from a Teams meeting/webinar into vmix, like what can be done with Zoom?
I really like the Zoom integration and the use of speech bubbles to bring in interaction from web attendees in hybrid conferences is great, but my organisation is trying to leave Zoom altogether (GDPR/Cloud Act reasons).
I think it might be possible by using the MS app Power Automate and use the "When a new message is added to a chat or channel" trigger and an Excel table/new row action, and then add the excel file to databse source manager in vmix, but I haven't had the time to figure it out yet.
kuuminsh
#2 Posted : Thursday, January 22, 2026 4:37:49 AM(UTC)
kuuminsh
Latvia
Here is a small problem with Excel.
There is no problem putting Teams notifications into an Excel table using PowerAutomatic.
The problem is that this Excel must be located in OneDrive and there is a big question as to how OneDrive will synchronize this Excel file.
From the PowerAutomatic side, everything is super basic.
I quickly checked:
"When a new chat message is added"
"Get message details"
And yes.. I receive all notifications in a specific chat in the powerautomatic environment. Then putting it into Excel is simple.
In my case, I did not go further, because I have several hundred GB on OneDrive and I suspect that OneDrive will synchronize these gigabytes
OscarE
#3 Posted : Thursday, March 12, 2026 4:12:55 AM(UTC)
OscarE
Sweden
So, I really forgot about testing this.
Had some time now and excel won't work because of sync/update problems when using OneDrive.
But I got csv working fine. The best way to do it I guess would be to write to a local file, but then you would have to install a local gateway server, so I used the OneDrive for Business commands in Power Automate.
1. Connect the flow to the corresponding meeting chat using "Teams: When a new message is added to a chat or channel"
2. Add a step to the flow using "Teams: Get message details" and reference your meeting chat
3. Create a csv file i your OneDrive folder (ie "chattest.csv"). Edit the file and add "User,Message" as the only content.
4. Add the "OneDrive for Business: Get file content" to the same step as in 2. and reference the previously created file
5. Add the "OneDrive for Business: Update file" to the same step as in 2. and reference the previously created file.
As "File Content", add the following dynamic content (write "/" to insert dynamic content):
-"Get file content/File content"
- hit enter for new row
- "Get message details/FromUser/displayName" or similar (as my PowerAutomate is in Swedish)
- add a ","
- "Get message details/Body/PlainTextContent" or similar
I haven't tried it in a live situation yet, but it works on the bench.
mavik
#4 Posted : Wednesday, July 15, 2026 5:05:41 AM(UTC)
mavik
I have created a MS Teams Townhall QA Manager. On bigger events we use town hall type events and when you enable the QA module for the meeting the manager gets the questions. Ranks the questions by votes and combines similar questions into one. Also an AI summary is generated for long questions. When a question is put to "On AIr" it is displayed as an overlay/lower third when you use the url as a web-input in vMix. Super simple. The only prerequisite is that you have to register an app with the message read rights in intune and use the tenant and app(client) ID, with the client secret. It cn be run as a service as well so that a repeated/permanent use is easy.
