I have both NDI and OMT running on vMix. Should I choose one of them, or should can use both? I’m considering the load they’ll put on my vMix pc.
Joined: 11/14/2012(UTC) Posts: 393  Location: Finland Thanks: 249 times Was thanked: 34 time(s) in 32 post(s)
If you don't need NDI video over internet and you can avoid other NDI sources then go for OMT -> More reliable - less mess.
It is over the LAN at the event
