TL68
#1 Posted : Saturday, July 4, 2026 12:36:48 AM(UTC)
TL68
Sweden
Hi all!
I'm looking into the possibility to toggle between a defined set of inputs on a layer on an input using a button on a streamdeck.
So that a button press changes to the next input on that layer on a predefined list of inputs.
Use case is to find an easy way to change input in a box on a splitview input without having to go into vMix settings or use up a lot of buttons on the streamdeck.
I would prefer if this was possible using the Companion software. But I would also be happy to map a button to shortcuts in vmix and/or script.
Thanks in advance for any help with this!
TL68
#2 Posted : Saturday, July 4, 2026 1:02:41 AM(UTC)
TL68
Sweden
Update: Mr AI helped me create a script that seems to do what I want :-)! I will run some more testing and then post it in the scripting forum.
TL68
#3 Posted : Monday, July 6, 2026 4:19:41 PM(UTC)
TL68
Sweden
Here is the script AI created for this function.
It works with input names to instead of input numbers.
Code:
' SETTINGS
' Change to your actual input numbers or names
Dim targetInput As String = "1"
Dim layerNumber As Integer = 1
Dim sourceInputs() As String = {"2", "3", "4"}
Dim xml As String = API.XML()
Dim x As New System.Xml.XmlDocument
x.LoadXml(xml)
' The correct XML path for vMix Dynamic Values is //dynamic/value1
Dim currentIndexNode As System.Xml.XmlNode = x.SelectSingleNode("//dynamic/value1")
Dim currentIndexStr As String = ""
If currentIndexNode IsNot Nothing Then
    currentIndexStr = currentIndexNode.InnerText
End If
Dim currentIndex As Integer = 0
' Attempt to convert the saved value to an integer
If Integer.TryParse(currentIndexStr, currentIndex) Then
    ' Move to the next input in the list
    currentIndex = currentIndex + 1
Else
    ' If the value is empty (e.g., the very first time the script runs)
    currentIndex = 0
End If
' If we have reached the end of the list, start over from zero
If currentIndex >= sourceInputs.Length Then
    currentIndex = 0
End If
' Get the name/number of the next input from the list
Dim nextInput As String = sourceInputs(currentIndex)
' Print info in the vMix Scripting log for troubleshooting
Console.WriteLine("Found saved index: " & currentIndexStr)
Console.WriteLine("Changing to index: " & currentIndex & " (Which is Input: " & nextInput & ")")
' Build the SetLayer command and send it to vMix
Dim layerValue As String = layerNumber.ToString() & "," & nextInput
API.Function("SetLayer", Input:=targetInput, Value:=layerValue)
' Save the new index so vMix remembers it for the NEXT time the script is executed
API.Function("SetDynamicValue1", Value:=currentIndex.ToString())
