msatv
#1 Posted : Tuesday, June 9, 2026 11:54:25 PM(UTC)
msatv
I am running vMix MAX and want to know if there is maximum number of inputs I can have? I mean, before everything crashes. I was running 85 yesterday with no issues. I run a variety of inputs, 3 cameras at 1080, then a mixture of small .mov files, audio and graphics(non-animated).
MickeyMJJ
#2 Posted : Wednesday, June 10, 2026 12:47:48 AM(UTC)
MickeyMJJ
My main project has over 240 inputs, including audio, video, images, playlists with multiple items, numerous NDI inputs (not all of which necessarily receive a stream, but the inputs are constantly pre-loaded), and many GT Titles. Four NDI outputs are always active. The project is running at 1920x1080 25fps and I haven't experienced any noticeable slowdowns.
My config : Alienware m18 R2 (Intel Core i9-14900HX, Nvidia GeForce RTX 4090 (16Go GDDR6), 32Go RAM DDR5-5600MHz)
knbPixels
#3 Posted : Tuesday, June 23, 2026 11:23:39 PM(UTC)
knbPixels
My team and I have high end spec'd PCs and we start having trouble when we get over about 260 inputs. We are at 255 right now
gustavop
#4 Posted : Sunday, July 26, 2026 6:27:51 AM(UTC)
gustavop
Uruguay
I've tested well over 350 Full HD videos, together with images, virtual sets and other production assets, on an Intel i7-9700 (3.0 GHz) with 16 GB RAM, and vMix has handled it surprisingly well.
In my experience, the practical limit depends much more on the type of inputs (NDI, videos, camera feeds, browser inputs, etc.), codecs, resolution and GPU performance than on the number of inputs alone.
If the layout contains a lot of PiP videos, you may notice some slowdown, but that's more of a PC performance limitation than a vMix limitation.
For my workflow, I haven't found the number of inputs to be the limiting factor.
