vMix Call
can't change Came and Mic in vmix call advanced menu
Joined: 10/10/2019(UTC) Posts: 61   Location: Düsseldorf Thanks: 3 times Was thanked: 14 time(s) in 8 post(s)
Hi all,
I just tested a vmix call and the user had problems to change the webcam to an external one. We are using always the advanced version of vmix call. After testing I found out that it is not possible anymore to change the webcam or mic in the vmix call advanced menu in chrome (Version 149.0.7827.54). After the reconnect chrome keeps the old webcam and mic. The only possible way to change a webcam or mic is in the Chrome settings. I tested Edge too and there its the same.
Can somebody do a quick test.
vMix Call
