Joined: 4/23/2017(UTC) Posts: 1,467  Location: Germany Thanks: 3 times Was thanked: 193 time(s) in 173 post(s)
Hi folks, I have created a pptx to NDI or OMT converter that sends a presenter feed and the presentation out both in 4k. It needs NDI Tools and powerpoint to function. It can open file paths as well as onedrive or sharepoint links using the logged in users authentication. There is also a refresh setting, a prevent sleep and transparent background option. Would this be of any help for anyone?
Joined: 6/29/2016(UTC) Posts: 104 Location: Luxembourg
Thanks: 48 times Was thanked: 14 time(s) in 12 post(s)
Originally Posted by: mavik  Hi folks, I have created a pptx to NDI or OMT converter that sends a presenter feed and the presentation out both in 4k. It needs NDI Tools and powerpoint to function. It can open file paths as well as onedrive or sharepoint links using the logged in users authentication. There is also a refresh setting, a prevent sleep and transparent background option. Would this be of any help for anyone? +1
Joined: 3/20/2026(UTC) Posts: 34  Location: Wilmington Thanks: 13 times Was thanked: 5 time(s) in 5 post(s)
Originally Posted by: mavik  Hi folks, I have created a pptx to NDI or OMT converter that sends a presenter feed and the presentation out both in 4k. It needs NDI Tools and powerpoint to function. It can open file paths as well as onedrive or sharepoint links using the logged in users authentication. There is also a refresh setting, a prevent sleep and transparent background option. Would this be of any help for anyone? Hey, Mavik! Yes, send me the download link. We'll test it out.
Rank:: Advanced Member
Joined: 11/27/2023(UTC) Posts: 124  Thanks: 9 times Was thanked: 8 time(s) in 8 post(s)
+1 send me the link to do a test
Joined: 5/14/2013(UTC) Posts: 155  Location: uk Thanks: 2 times Was thanked: 28 time(s) in 24 post(s)
hi can i get the download link
 1 user thanked Henny for this useful post.
It looks like we can 't wait 🤔 😂
where is that link...where is that link.....we want to test this...yeh wanna test it .....can't wait to get my hands on it.....wanna be a beta tester
 1 user thanked Luis70 for this useful post.
There is a new version available (same download link) that reduces the latency for clicks. It uses a pre-warmed cache keeping the next slide immediately available. It also listens to http, tcp, udp commands so that controlling it through tools like Octocue makes it super fast and direct.
