HP Z8 G5 dual socket Xeon Gold 6526Y + DeckLink Quad 2 — compatibility and DPC latency concerns
Joined: 6/3/2026(UTC) Posts: 3  Location: Buenos Aires Thanks: 1 times
We are planning to replace our current broadcast streaming workstation with an HP Z8 G5, and before purchasing I wanted to check if anyone has experience running vMix on this platform.
Current setup (working, but being replaced): - Dell Precision 7960 Tower - Intel Xeon w5-3423 (single socket, 12 cores, 2.1GHz base) - NVIDIA RTX A4000 16GB - 2x Blackmagic DeckLink Quad 2 (Desktop Video 14.5) - Dante Virtual Soundcard in ASIO mode (Allen & Heath SQ7 console) - vMix 28.0.0.42 x64 - Daily live streaming operation, 8+ hours per day
Planned new system: - HP Z8 G5 Tower - 2x Intel Xeon Gold 6526Y (dual socket — 16 cores each, 2.8GHz base, 3.9GHz turbo) - NVIDIA RTX PRO 4500 Blackwell 32GB GDDR7 - 2x Blackmagic DeckLink Quad 2 (reusing existing cards) - Dante Virtual Soundcard in ASIO mode (same audio setup) - Intel X550-T2 10GbE dual port NIC (for Dante traffic) - 128GB DDR5 5600 ECC RAM
My main concerns before purchasing:
1. Dual socket NUMA architecture — vMix is known to benefit from high per-core clock speeds rather than high core counts. In a dual socket system, threads crossing the UPI bus between sockets can introduce memory access latency. Has anyone experienced DPC latency or real-time audio issues specifically related to NUMA in a dual socket Xeon configuration running vMix?
2. DeckLink Quad 2 reuse — the existing PCIe Gen 2 x8 cards will go into PCIe Gen 4/5 slots. Backward compatibility should be automatic, but has anyone confirmed this works without issues with Desktop Video 14.5 or newer?
3. Intel X550-T2 10GbE NIC with Dante Virtual Soundcard — any known DPC latency issues with this NIC under heavy vMix load?
Context: on our current Dell system we experienced audio corruption (pops, dropouts) in the HD-SDI output after several hours of operation. We identified high DPC latency from ndis.sys and BlackmagicIO.sys as the root cause via LatencyMon, and a Windows cumulative update (KB5083769) that worsened the issue. We resolved it by uninstalling the update, setting CPU affinity for vMix to avoid the most interrupt-heavy cores, and applying MMCSS tweaks. We want to ensure the new hardware does not introduce similar or worse latency issues.
Any experience, advice, or official guidance on dual socket Xeon configurations with vMix would be greatly appreciated.
Thank you.
Thanks: 8 times Was thanked: 12 time(s) in 9 post(s)
I think dual socket isn't advised. I doubt it will be any better than one 32-core xeon-w at 2.5GHz base. Also, hasn't there been issues with Dante on 10G ports/networks? Maybe it has been fixed? You can get 1024 channels of 48KHz/24bit audio on a 1 GbE connection btw...
BTW I also have issues with a Dell workstation with high DPC latencies the most probable cause. I have audio dropouts at random points.
 1 user thanked Anders for this useful post.
Originally Posted by: Anders  I think dual socket isn't advised. I doubt it will be any better than one 32-core xeon-w at 2.5GHz base. Also, hasn't there been issues with Dante on 10G ports/networks? Maybe it has been fixed? You can get 1024 channels of 48KHz/24bit audio on a 1 GbE connection btw...
BTW I also have issues with a Dell workstation with high DPC latencies the most probable cause. I have audio dropouts at random points. Thank you so much for your response — it was really helpful and confirmed what we were already suspecting about the dual socket architecture. By the way, after extensive troubleshooting, we were able to trace the root cause to a Windows Cumulative Update (KB5083769, build 26200.8246) installed in April 2026, which significantly increased DPC latency on ndis.sys. Uninstalling the update brought it back down to normal values. We also found that setting CPU affinity for vMix to avoid the most interrupt-heavy cores (0-7 in our case) helped prevent the dropouts. Have a great day.
