Joined: 8/31/2020(UTC) Posts: 35   Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
My church I volunteer for asked a question and Im not sure where to find it.
Each week when we click on the YouTube StreamKey it is the same but the one in the Vmix is different and we have to click and paste it each week which is tough for a couple operators. How can we save the you tube link so it stays when we paste it?
Would appreciate some help.
Joined: 11/27/2023(UTC) Posts: 137  Thanks: 10 times Was thanked: 11 time(s) in 11 post(s)
Just tell the other users not to change the 'stream key'....I stream for months using the same stream URL and stream key without any issues
Joined: 9/22/2020(UTC) Posts: 45  Thanks: 3 times Was thanked: 5 time(s) in 5 post(s)
Add a profile, which is a save preset basically...
Originally Posted by: Luis70  Just tell the other users not to change the 'stream key'....I stream for months using the same stream URL and stream key without any issues Not sure what they are doing, but the statement is that the stream key changes in VMIX and they are required to copy the link again each time. Im just trying to figure out how to make VMIX keep the one they paste in there. Im trying to duplicate it on my copy (I create their slides show every week as a volunteer), but mine keeps it that I can see. Ill try and work on it some more. Hopefully someone will pipe in. Rick
