lestra
#1 Posted : Thursday, May 21, 2026 3:44:20 PM(UTC)
lestra
Saint Kitts And Nevis
I need some urgent help regarding SRT Caller inputs.
For an upcoming live broadcast, the camera crew on the field provided me with 5 different SRT URLs from their relay server. All of them share the exact same Host Name and Port. The only difference is the Stream ID for each camera.
Here is how the URLs look (using fake data for privacy):
srt://host.com:9000?streamid=camera1&passphrase=pass1
srt://host.com:9000?streamid=camera2&passphrase=pass2
srt://host.com:9000?streamid=camera3&passphrase=pass3 ...and so on.
The Problem:
When I try to add these as separate SRT Caller inputs, vMix seems to index them strictly by the IP:Port combination. Every time I add a new input and change the Stream ID, vMix automatically overwrites/updates the Stream ID on the previously created input as well. It treats them as the exact same source and won't let me have 5 independent inputs active at the same time.
I need to have access to these separate sources to mix them during the live event. How can I bypass this limitation and force vMix to treat them as independent inputs?
Thanks in advance for the help!
Kayo33
#2 Posted : Thursday, May 21, 2026 10:35:34 PM(UTC)
Kayo33
Was thanked: 18 time(s) in 14 post(s)
Hi
maybe try inputs SRT (Listener)?
lestra
#3 Posted : Friday, May 22, 2026 12:24:08 AM(UTC)
lestra
it is connection via server srt relay, both sides must be caller
lestra
#4 Posted : Sunday, May 24, 2026 3:08:46 AM(UTC)
lestra
Just modified host file and it works.
Guest (4)
