Change FPS and Resolution for SRT, While Leaving RTMP As Is?
I have a usecase where I need to send my stream to: Location 1: YouTube RTMP - using my canvas resolution of 1920x1080 50fps Location 2: SRT recipient, who wants 1280x720 at 25fps I cannot find a way to configure SRT output to use a lower resolution for FPS? The SRT output is set to Output 2. And under Settings > External Output 2 I have configured the page as follows: https://i.imgur.com/4su5cJQ.pngAnd tried: https://i.imgur.com/BXnwp8b.pngAnd yet the SRT feed is still sending 1920x1080 50FPS. Can this be changed?
Joined: 10/31/2020(UTC) Posts: 196  Thanks: 5 times Was thanked: 43 time(s) in 42 post(s)
I know I'm a little late in responding, but a possible workaround is to use a separate program, such as OBS, or even a second instance of vMix, to stream SRT. Output from vMix to other program via NDI, then other program can output SRT using whatever settings are needed. I know it's not ideal, but it's better than nothing I suppose. :)
Joined: 10/20/2023(UTC) Posts: 139  Thanks: 3 times Was thanked: 16 time(s) in 12 post(s)
