Problem with video "yellow vertical line"
Joined: 7/27/2019(UTC) Posts: 48  Location: BGD Thanks: 5 times
 Capture.PNG (1,625kb) downloaded 63 time(s).Hi all, We are rendering all files in the same codec before entering inf VmiX. For the last 3-4 months, we have an issue where on some files we can see a YELLOW Vertical line in the preview, but also on program out while playing video files. We updated the new K-lite codec, the newest NVIDIA driver, and also updated VmiX to the newest version .. But no help.
now we have this issue on two computers...
Joined: 11/27/2023(UTC) Posts: 137  Thanks: 10 times Was thanked: 11 time(s) in 11 post(s)
Try uninstalling the K-lite drivers and see if that works...had many issues with those a few years ago, uninstalled them, and never reinstalled them again
Originally Posted by: Luis70  Try uninstalling the K-lite drivers and see if that works...had many issues with those a few years ago, uninstalled them, and never reinstalled them again
just done that.. same thing as u can see on image bellow  Capturedd.PNG (1,855kb) downloaded 44 time(s).
re all the clips the same resolution, all HD, or is there a mixture of HD and 4k... and which clips have that yellow line....if it is the 4k, then your video card will need upgrading.
Originally Posted by: Luis70  re all the clips the same resolution, all HD, or is there a mixture of HD and 4k... and which clips have that yellow line....if it is the 4k, then your video card will need upgrading.
All our clips goes thru same encoder "Shutter Encoder OpenGL" where we put all clips to "auto 1920", and normalize audio on -5db in h264 codec. So all are in HD ... some are 16:9, some are 9:16 ... I did not find any clue or logical connection in aspect ratio or something else..
