Need help with URL Input keyboard input, Please help asap
Joined: 2/7/2024(UTC) Posts: 183  Thanks: 12 times Was thanked: 6 time(s) in 5 post(s)
Create a URL input in vmix, http://www.google.com for example. Enable keyboard, and attempt to type into the search field on the webpage. For some reason the "H" key does not work. Pasting text does not work. Large impact on a feature we would like to add to our show.
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: knbPixels  Create a URL input in vmix, http://www.google.com for example. Enable keyboard, and attempt to type into the search field on the webpage. For some reason the "H" key does not work. Pasting text does not work. Large impact on a feature we would like to add to our show. No problem here typing an H
Joined: 1/25/2019(UTC) Posts: 331  Thanks: 24 times Was thanked: 84 time(s) in 64 post(s)
i can add a browser window in vMix, google.com, enable keyboard and can type in any character in googles search text input field, in the preview window in vMix. i can even copy & paste doggy's H (thanks for that) search somewhere else, are you using a keyboard macro program? any script that looks for a keypress, any keyboard shortcut in vMix, that uses M broken keyboard?
Originally Posted by: Peter1000  i can add a browser window in vMix, google.com, enable keyboard and can type in any character in googles search text input field, in the preview window in vMix. i can even copy & paste doggy's H (thanks for that) search somewhere else, are you using a keyboard macro program? any script that looks for a keypress, any keyboard shortcut in vMix, that uses M broken keyboard? This is occurring for us on the latest vMix version, across 5 different producer setups. The site in use doesn't matter, H still won't work. No scripts looking for keys, and we have a few shortcuts, but none that use the H key.
Joined: 10/31/2020(UTC) Posts: 197  Thanks: 6 times Was thanked: 44 time(s) in 43 post(s)
Well, as a possible workaround until you get this figured out, instead of creating a web browser input in vMix, just open a web browser (Chrome, Firefox, etc) and create an input in vMix that captures that window. You can crop, zoom, etc in vMix to remove the title bar and borders.
