Instant Replay
Really struggling with replay stingers.
Joined: 8/3/2015(UTC) Posts: 325 Location: Chicago, IL
I am in need of being able to cue 4 different stinger transitions for the instant replay events. Each stinger has its own graphic logo that needs to be displayed over the replay video as well.
I have been looking at the forums for weeks (been around here for years) trying different solutions and found a lot of dead ends and feature requests.
I am trying to use the SetStingerGTInput1 shortcut, it says it can load a specific title into the Stinger 1 overlay slot? But I can’t seem to get it to function.
Any help would be greatly appreciated.
Chucky P
Joined: 5/5/2026(UTC) Posts: 1  Location: Middles Brough
I’ve run into something similar when trying to juggle multiple replay stingers in vMix. From what I found, SetStingerGTInput1 can be a bit misleading depending on the version—sometimes it won’t actually swap what you expect unless the Stinger is already properly assigned to the overlay channel and the GT title parameters are correctly exposed. In a lot of setups, people end up having better luck controlling multiple stingers by pre-loading them into separate inputs and then triggering them via shortcuts rather than trying to dynamically swap a single stinger slot. Also worth double-checking that your titles are actually exposed to GT so vMix can “see” them as switchable elements. I came across a breakdown that might help clarify how stinger assignment and triggering behaves in practice on this website (worth a look for how people are structuring layered replay graphics workflows).
Joined: 12/27/2012(UTC) Posts: 5,516  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: Cpilcher  I am in need of being able to cue 4 different stinger transitions for the instant replay events. Each stinger has its own graphic logo that needs to be displayed over the replay video as well.
Chucky P to be able to select which stinger to use on the go create a blank transparent input and put your stingers in its layers Unselect all layers and select the one you want to use Select the blank input as a stinger(#) overlay ( specify the timings, best is to have all used stingers to match this equally) Select that stinger(#) as the one in your replay settings Selecting which layer/stinger to use can be changed with shortcuts/script
Instant Replay
