The SRT protocol does support setting language metadata for audio tracks, which is helpful when working with multiple audio tracks. For example, the streaming platform 3q.video does support automatically reading the language tags from the SRT signal and delivering them to the HLS output. In more technical terms: Quote:Multi-audio SRT should support setting ISO 639 language tags (-metadata:s:a:X language=...) as MPEG-TS PMT descriptors to ensure correct audio track identification in downstream playback and packaging workflows. ffmpeg example on how to set these: Quote:ffmpeg \ -re -i input.mp4 \ -map 0:v:0 \ -map 0:a:0 \ -map 0:a:1 \ -c:v copy \ -c:a aac \ -metadata:s:a:0 language=eng \ -metadata:s:a:1 language=deu \ -f mpegts \ "srt://ingest.example.com:1234?mode=caller"
Joined: 4/23/2017(UTC) Posts: 1,480  Location: Germany Thanks: 3 times Was thanked: 194 time(s) in 174 post(s)
The European problem which is completely ignored by the english speaking countries. +1000
Joined: 11/14/2012(UTC) Posts: 357  Location: Finland Thanks: 224 times Was thanked: 24 time(s) in 22 post(s)
Rank:: Member
Joined: 8/14/2023(UTC) Posts: 13  Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Joined: 10/10/2019(UTC) Posts: 63   Location: Düsseldorf Thanks: 3 times Was thanked: 14 time(s) in 8 post(s)
