support t4s
#1 Posted : Thursday, April 30, 2026 12:10:17 AM(UTC)
support t4s
Italy
Hi Guys,
We handle the entire female soccer league matches with VMix.
Today, physical SDi sources are becoming increasingly rare, and REMI productions are increasingly IP-based.
While working on some scripts and automations using APIs and VB.NET, I realized there is no API command available to change the input type within an existing source-specifically, to select SRT and enter the Host and Ports. In fact, I also noticed there is no "ADD Input" function that allows you to create and configure an SRT source.
I look forward to your feedback.
ryxyz
#2 Posted : Thursday, April 30, 2026 6:52:27 AM(UTC)
ryxyz
Was thanked: 11 time(s) in 4 post(s)
+1
Kotin
#3 Posted : Sunday, May 24, 2026 7:17:00 AM(UTC)
Kotin
+1
