TLS 1.3 Not Supported for DataSources?
Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
We have a New API we have built to act as a Datasource via JSON in Vmix - using 29.0.0.46 right now. However when we use the HTTPS address of our server it fails with an SSL/TLS negotiation error. WE have nailed this down to the fact our Firewall WAF was set to enforce TLS 1.3 - as it does this for extra security for ALL of our internal Web servers. However this is when we get the error. I temporarily changed the Global value to TLS 1.2 Capabale - and the JSON source works with HTTPS.
This is not ideal - so wondering if there is some tweak somewhere we can force VMIX to try TLS 1.3? or is it something you still need to Bake into the Code for support.
Joined: 3/28/2016(UTC) Posts: 172   Location: SACRAMENTO Thanks: 6 times Was thanked: 27 time(s) in 22 post(s)
What OS are you on? Win10 or Win11? if you're on Win11 you can try adding this to the vm config file:
<runtime> <AppContextSwitchOverrides value="Switch.System.Net.DontEnableSystemDefaultTlsVersions=false"/> </runtime>
I believe it already has a runtime section so just find it and put the config line in there.
If your on win10 you'll need to do a registry change like so:
Find the following path in the left panel of the Registry Editor: [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.3\Client] Double-click on [Enabled]. In the [Value data] field, change the value to [1] and click [OK].
Obviously test this but this should work for you.
