Multiple output Resolutions - to record Zoom Calls
Hi all,
I see that Zoom Calls do not work with multi-corder, so I'd like to use the multiple outputs as a way to record multiple zoom inputs. I use the first output to send 1080 out for the live event, and I'd love to set output 2 to work in 4k so that i can combine 4x1080 zoom calls all into one frame and capture that for later editing.
Is this possible? Seemed like all outputs need to be the same resolution, but i hope not.
@ bencodec
You will likely need to set your vMix project to 4K for Output 2 to be 4K, then a quad box of 1080p sources will not lose resolution.
