I would like to get my data source to reset to row 3 whenever it hits a empty row as the data we have coming in is always changing the number of rows we have. This is the current script I have that works great to rotate throughout a certain amount of rows but if I have it set to rows 3-6 as thats about the max we would need but only 3 & 4 are getting used it sits on row 4 for the time that it would be on 5 & 6 if there was data in there.
' Define your range (vMix indices start at 0) Dim startRow As Integer = 2 ' Actual row 3 Dim endRow As Integer = 3 ' Actual row 4 Dim delay As Integer = 10000 ' Time in milliseconds (10 seconds) Dim dataSource As String = "TimingTest" ' Your Data Source Name Dim table As String = "Sheet1" ' Your Table Name Do While True For i As Integer = startRow To endRow ' Select the row API.Function("DataSourceSelectRow", Value:=dataSource & "," & table & "," & i) Sleep(delay) Next Loop
Originally Posted by: AndrewH  I would like to get my data source to reset to row 3 whenever it hits a empty row as the data we have coming in is always changing the number of rows we have. This is the current script I have that works great to rotate throughout a certain amount of rows but if I have it set to rows 3-6 as thats about the max we would need but only 3 & 4 are getting used it sits on row 4 for the time that it would be on 5 & 6 if there was data in there.
' Define your range (vMix indices start at 0) Dim startRow As Integer = 2 ' Actual row 3 Dim endRow As Integer = 3 ' Actual row 4 Dim delay As Integer = 10000 ' Time in milliseconds (10 seconds) Dim dataSource As String = "TimingTest" ' Your Data Source Name Dim table As String = "Sheet1" ' Your Table Name Do While True For i As Integer = startRow To endRow ' Select the row API.Function("DataSourceSelectRow", Value:=dataSource & "," & table & "," & i) Sleep(delay) Next Loop Do a check on the data being "empty" by means of a title content read
