Joined: 3/20/2020(UTC) Posts: 32  Location: Oregon Thanks: 1 times Was thanked: 4 time(s) in 4 post(s)
There is a Clone/copy option for shortcuts. I would suggest this would be a good option for Scripts as well. Second, the ability to re-order the script list for grouping related scripts together would be super helpful.
Originally Posted by: mikesg  There is a Clone/copy option for shortcuts. I would suggest this would be a good option for Scripts as well. Second, the ability to re-order the script list for grouping related scripts together would be super helpful. One can copy and paste like any text editor, one can also export/import a script (Is also just text file) There is also a script to export ALL the scripts as individual files might be helpful for reordering them https://forums.vmix.com/...eature-Request#post95653Second, agree reordering would be supper helpful
Copy and pasting the text of the script is one part. The name is the other. A clone button would allow for duplication then editing for both in an efficient way. I had to make a couple dozen short scripts that change some text. I made all the scripts and named them first, then edited each one for the script contents. Would have been nice not to have to do those things independently of each other.
