MartinC79
#1 Posted : Tuesday, March 24, 2026 2:51:41 AM(UTC)
MartinC79
Argentina
Hello vMix forums, I am working on a live project which involves using ~22 live feed cameras, one at a time. I´ve been managing this with an external python script that swaps inputs when needed, basically hopping between cameras, the thing is that having all 22 cameras loaded as different inputs all at once is obviously very taxing on CPU and bandwidth, which is why I am looking for a way to handle this in a more efficient way. I tried with the AddInput command, using the function as follows: FUNCTION AddInput Value=Image|c:\path\to\image.jpg\r\n
Replacing "Image" with "Stream", "VLC", "Flash" and others has not worked, I´ve been using the camera RTSP url for the path parameter, also, as far as I know, there is no way to dynamically change the url of a loaded RTSP Stream input via API, so I ask: Is there any other way of achieving this that I´m ignoring? Maybe some vMix Scripting magic?
Thank you very much in advance for reading this :D
