gre2gor
#1 Posted : Tuesday, October 28, 2025 1:05:14 PM(UTC)
gre2gor
Slovenia
Was thanked: 18 time(s) in 7 post(s)
With the recent release (vMix 29), we can now access TimeCode in the API, which is great progress for external replay integrations.
However, one key piece of information is still missing: there’s currently no way to determine which replay event is currently selected, or which camera angles are active for that selected replay event, directly via the API.
This makes it difficult to synchronize external control surfaces or Stream Deck feedback with the replay module.
At the moment, the only workaround is to query both the API and replay2.xml:
The API gives general replay input data and TimeCode
replay2.xml lists all replay events, including selected angles and IDs
Unfortunately, these two sources cannot be directly linked — the API does not expose the event ID, and the XML’s timecodes differ from those in the API. As a result, there’s no reliable way to map the “currently selected replay” in the API to its corresponding entry in replay2.xml.
If the API could:
Provide the ID of the currently selected replay event, and/or
Include which angles are selected for that event
…it would eliminate the need for an external XML query and significantly improve integration possibilities for control systems and Stream Decks.
This would allow operators to instantly see which replay and camera angles are armed for playback — a critical need in live production where quick visual feedback and control are essential.
thanks 1 user thanked gre2gor for this useful post.
cgroom on 10/28/2025(UTC)
monamiga
#2 Posted : Saturday, November 15, 2025 11:02:49 AM(UTC)
monamiga
Philippines
+1
TrondH
#3 Posted : Monday, March 23, 2026 9:55:47 PM(UTC)
TrondH
Norway
+1
In addition it would be great to add via the API "select clip" (by event ID) not only previous or next clip.
gre2gor
#4 Posted : Monday, March 23, 2026 10:03:30 PM(UTC)
gre2gor
Slovenia
I hope Vmix read this and they decide to implement it, since they already have everything, just needs to expose info with some new api call?
aircooled76@gmail.com
#5 Posted : Thursday, April 23, 2026 11:54:52 AM(UTC)
+1 Yes please!
Guest (4)
