Feature Requests
GT Designer Improvements for Broadcast Graphics and MOS Newsroom Workflows
Joined: 3/17/2026(UTC) Posts: 2  Location: Guarulhos Was thanked: 1 time(s) in 1 post(s)
Hello everyone,
I would like to share some feedback based on my recent work implementing vMix in broadcast environments here in Brazil.
Recently I have been working on several projects migrating lower thirds and broadcast graphics packages from systems such as Vizrt and Aximmetry to vMix. This type of migration has been growing significantly, especially for productions that are looking for a more flexible and cost-effective solution.
In addition to rebuilding the graphics, I am currently working on implementing MOS integration so that NRCS systems such as Arion and ENPS can communicate with vMix. In this workflow, I configure the graphics templates in vMix and replicate the lower thirds so they can be triggered directly from the newsroom system.
During these implementations we noticed that some common broadcast graphics behaviors are still difficult to reproduce inside GT Designer. Because of that, I would like to suggest a few improvements that could significantly enhance the broadcast graphics workflow in vMix.
Suggested Improvements
1. Text Auto-Fit by CompressionCurrently the shrink option reduces the font size. However, many broadcast graphics systems allow text to compress horizontally to fit inside a predefined area. This is a common behavior for lower thirds and name straps in broadcast systems.
2. Keyframe-Based AnimationAdding the ability to animate elements using keyframes would provide much more control over motion design inside GT Designer. This would allow users to build more advanced animations without relying on external rendering.
3. Dynamic Text Field InteractionAllow text fields to dynamically reposition each other.
Example workflow:NameJob Title
If the name becomes longer, the job title would automatically move to the right or adjust its position accordingly. This behavior is very common in newsroom graphics.
4. More Overlay ChannelsIn complex productions, especially in news environments, we often need to stack multiple graphics layers simultaneously. Increasing the number of overlay channels would provide much more flexibility.
Why this matters
These improvements would make it significantly easier to migrate existing broadcast graphics packages from systems like Vizrt and Aximmetry into vMix. They would also help vMix become an even stronger solution for newsroom workflows, MOS automation, and live broadcast graphics.
Thank you for the continuous development of vMix and the great work on GT Designer.
Joined: 5/14/2013(UTC) Posts: 155  Location: uk Thanks: 2 times Was thanked: 28 time(s) in 24 post(s)
Hi I have been doing bradcast graaphics in vmix for a while and am now moving away to HMTL/CSS/Java script , espeshley now OGraf is geting some momenntun ,OGraf is an Open specification for HTML based Graphics, used in live television and post production workflows , the EBU have a working group on it https://tech.ebu.ch/groups/html_graphics and more info can be found at https://ograf.ebu.io/
Joined: 4/23/2017(UTC) Posts: 1,491  Location: Germany Thanks: 3 times Was thanked: 198 time(s) in 178 post(s)
To add an option for more overlays (#4): You can add the graphics in layers of a single shot and activate each layer independently. This way you use one overlay (for the single input) and can use the 9 layers as overlays inside it. Now with 8 overlay channels you could have 8x9 = 72 overlays. I think this is more than enough. Just be creative.
Joined: 12/8/2022(UTC) Posts: 165  Thanks: 50 times Was thanked: 3 time(s) in 3 post(s)
+1 on all of the above! Except for maybe more overlay channels. Since we got eight in version 29 I am pretty much set for now :-)
Thanks for the feedback — great to see others working with similar setups!
I agree that the increase to 8 overlays in v29 was a very important improvement and already covers many use cases.
From my experience working with broadcast graphics migration and MOS-driven workflows, we still encounter scenarios where more simultaneous layers are required — especially when combining multiple lower thirds, bugs, tickers, fullscreens, and automated elements coming from the NRCS.
In more traditional broadcast graphics systems, it’s quite common to have a more flexible layering approach or a higher number of available layers, which makes it easier to replicate complex on-air packages without workarounds.
So while the current implementation works well for many productions, having additional overlays (or a more flexible layering system) would further improve vMix’s capability in high-end broadcast environments.
If helpful, I can also share examples of broadcast templates and newsroom workflows used in these integrations.
 1 user thanked Seni for this useful post.
Joined: 1/16/2018(UTC) Posts: 37 Location: Bern, Switzerland
Thanks: 4 times Was thanked: 4 time(s) in 4 post(s)
Originally Posted by: Henny  Hi I have been doing bradcast graaphics in vmix for a while and am now moving away to HMTL/CSS/Java script , espeshley now OGraf is geting some momenntun ,OGraf is an Open specification for HTML based Graphics, used in live television and post production workflows , the EBU have a working group on it https://tech.ebu.ch/groups/html_graphics and more info can be found at https://ograf.ebu.io/ Any plans on aligning / integrating with OGRAF and other HTML based graphics standards @martin and team? This looks like a promising way to overcome limitations and lock-in
 1 user thanked hidavid for this useful post.
Feature Requests
