gre2gor
#1 Posted : Monday, October 27, 2025 6:12:56 PM(UTC)
gre2gor
Slovenia
Was thanked: 18 time(s) in 7 post(s)
With the recent release (vMix 29), we can now access TimeCode in the API, which is great progress for external replay integrations.
However, one key piece of information is still missing: there’s currently no way to determine which replay event is currently selected, or which camera angles are active for that selected replay event, directly via the API.
This makes it difficult to synchronize external control surfaces or Stream Deck feedback with the replay module.
At the moment, the only workaround is to query both the API and replay2.xml:
The API gives general replay input data and TimeCode
replay2.xml lists all replay events, including selected angles and IDs
Unfortunately, these two sources cannot be directly linked — the API does not expose the event ID, and the XML’s timecodes differ from those in the API. As a result, there’s no reliable way to map the “currently selected replay” in the API to its corresponding entry in replay2.xml.
If the API could:
Provide the ID of the currently selected replay event, and/or
Include which angles are selected for that event
…it would eliminate the need for an external XML query and significantly improve integration possibilities for control systems and Stream Decks.
This would allow operators to instantly see which replay and camera angles are armed for playback — a critical need in live production where quick visual feedback and control are essential.
InstantReplayGO
#2 Posted : Sunday, March 15, 2026 3:53:58 AM(UTC)
InstantReplayGO
Brazil
Was thanked: 8 time(s) in 3 post(s)
+1
We want this information on API, and possibility to access a clip(events) directly on shortcut, like EVS bank, pages, clips
thanks 1 user thanked InstantReplayGO for this useful post.
Srivelles on 3/31/2026(UTC)
