So far the move 4k 30x camera i'm testing is such that: --Upgrade tool tells me it has ip address 192.168.100.88 --but ipconfig reports it as 169.254.79.236 --i can't connect to the camera via browser using either address --vmix can't find the camera via ndi. Yes ndi tools installed
--vmix does find it when i send it thru a decklink duo 2 but no vmix ptz control is available. Camera settings table can't connect to the camera. --i can see camera output via hdmi direct to a monitor
Any ideas welcome.
The 169.x IP indicates "I get nothing". Have you tried to manually change your NIC adapter to an IP in that subnet like 192.168.100.12 mask 255.255.255.0 gateway blank and then tried to access the cam on it's .88 IP. Once you are in you can change the cam IP to DHCP and can get to it by the cog of NDI monitor or from vMix by right click on the input and then "configure source".
