GT
Problem with animating text out
Hey, I've made a lower third in gt designer using a combination of an image sequence and text boxes. I can animate in the text fine and fade it out. The only issue I have is keeping it animated out and not just cutting back in. I read in another post that in the transition out 'Hidden' keeps it away but that doesn't seem to work. I've attached a video to show the issue. Hopefully someone can help! Video of issue here!
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
Originally Posted by: toasty23  Hey, I've made a lower third in gt designer using a combination of an image sequence and text boxes. I can animate in the text fine and fade it out. The only issue I have is keeping it animated out and not just cutting back in. I read in another post that in the transition out 'Hidden' keeps it away but that doesn't seem to work. I've attached a video to show the issue. Hopefully someone can help! Video of issue here! Put it into vMix, overlay it there and look if it behaves the way you want it. As I see it, the text re-appears again just for further editing in the Title Designer. The Transition is over.
Originally Posted by: toasty23  Hey, I've made a lower third in gt designer using a combination of an image sequence and text boxes. I can animate in the text fine and fade it out. The only issue I have is keeping it animated out and not just cutting back in. I read in another post that in the transition out 'Hidden' keeps it away but that doesn't seem to work. I've attached a video to show the issue. Hopefully someone can help! Video of issue here! First of this is normal behavior in designer mode, at end of timeline it reverts to initial design/edit state. One has to actually use it in the production for the full effect Just use a fade in (no reverse) and a fade out
GT
