Instant Replay
Possible to set new in and out on exesting replay event instad of moving?
Joined: 12/8/2022(UTC) Posts: 162  Thanks: 48 times Was thanked: 3 time(s) in 3 post(s)
Hi! I am trying to find a command or function to set new in and out points on an already existing replay event. I can move the existing in and out with the move commands. But I would also like to be able to play the existing captured event in preview, pause and then run a command to set the in point at the playhead position and then do the same with the out point. (Sort of the way it works in my video editing software pressing "I" and "O" on the timeline.) If I try pressing mark in and mark out with an existing event in preview a new replay event is created instead of setting new in/out on on the existing one.
Is this possible at all and if so how?
Thanks in advance for any input!
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: TL68  Hi! I am trying to find a command or function to set new in and out points on an already existing replay event.
Please check the Shortcut function reference list in the vMix help files (or when creating a shortcut)! Something like ReplayUpdateSe..... will do the trick
Originally Posted by: doggy  Originally Posted by: TL68  Hi! I am trying to find a command or function to set new in and out points on an already existing replay event.
Please check the Shortcut function reference list in the vMix help files (or when creating a shortcut)! Something like ReplayUpdateSe..... will do the trick Thanks Doggy! I think I found it: ReplayUpdateSelectedInPoint = Update In point of Selected Event to current Position. ReplayUpdateSelectedOutPoint = Update Mark Out point of Selected Event to current Position. Will try as soon as possible (working from home now so no vMix to play with)
Update:
ReplayUpdateSelectedInPoint and ReplayUpdateSelectedOutPoint works like a charm just like I want! Yey!
Must make a reminder to myself to always look into the shortcut list and api function list when trying to solve stuff in vMix.
In this case I was looking for this function in Companions vMix plugin list and it was just not there. And there are no buttons in the interface for it.
Now I run it as a vmix scripting custom command in companion and it works fine.
Joined: 4/3/2022(UTC) Posts: 38  Thanks: 7 times Was thanked: 21 time(s) in 9 post(s)
as others have mentioned, please refer to the vMix Shortcut Function reference if you ever want to explore 'can I press a button to XYZ?' aaaaaaaaaand here's a link you can open from anywhere (this one is for vmix 29): https://www.vmix.com/hel...utFunctionReference.html
Instant Replay
