nakedeye
#1 Posted : Wednesday, March 11, 2026 12:12:25 PM(UTC)
nakedeye
We use this app for controlling our Hyperdeck for use as a replay source.
Okay here is the download link.
https://drive.google.com...blyM8qycVSE8?usp=sharing
If you are prompted to log into a goggle account to download then copy and paste the link into an incognito window.
You will need to update you Hyperdeck HD Mini software to the latest for that model. You will need to have the deck on the same network as the controller, if you use the basic vMix integration then the same network is also required. You will need to configure your firewall.
Extensive keyboard shortcuts make this simple and efficient to use, label presets text can be easily edited/customized and reloaded. Does not support spanned recording for replay lists so stop and switch slots.
