Overlay Input in/out onto two seperate inputs at same time
I have to send out a stream to different takers and they want different layouts than each other
Input 1 - Programm Feed - The main feed that will go to YT etc - RTMP Input 13 - Alternate Feed - This will only use 2 cameras and a lower third graphic - SRT
Input 1 has input 2 Camera as a cropped layer and Input 3 camera as a PiP overlay Input 13 has Input 2 Camera as a full screen layer and Input 3 Camera as a PiP overlay
At the moment I can get input three to transition in and out on input 1, but I cannot get it to trigger on input 13 at the same time when pressing the transition in shortcut key
Is this even possible. I am still finding my way around vMix
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
Originally Posted by: KNTR  I have to send out a stream to different takers and they want different layouts than each other
One way is to use a Mix input for your 2nd output, and set up a shortcut to send the overlay to PGM and to the Mix input ("Mix 1 and Mix 2").
 1 user thanked dmwkr for this useful post.
Wow,
I have spent the last 4 hours battling with ChatGpt and watching various other videos to achieve what you jsut helped with in 1 minute!
Thanks!
