TL68
#1 Posted : Friday, March 6, 2026 12:46:15 AM(UTC)
TL68
Sweden
So I played around a bit and found the "create virtual input" on the input settings page.
Seems as if it creates another input with the same settings as the original. This seems handy.
But is there anything else with virtual inputs to consider and watch out for?
Having trouble finding any substantial information in the manuals and vmix tutorial videos (probly just me lousy att search...).
kayllastudio
#2 Posted : Friday, March 6, 2026 4:06:35 AM(UTC)
kayllastudio
Was thanked: 12 time(s) in 7 post(s)
?si=8haBLPpooKuFkkJk
thanks 1 user thanked kayllastudio for this useful post.
TL68 on 3/6/2026(UTC)
TL68
#3 Posted : Friday, March 6, 2026 5:15:47 PM(UTC)
TL68
Sweden
Thanks, but this video does not really explain the virtual inputs in any detail more than a easy way to duplicate a input to add effects. And maybe this is the best use case for them?
I was wondering about how the work when it comes to performance vs using regular inputs, other use cases, problem areas etc.
mavik
#4 Posted : Sunday, March 15, 2026 1:53:16 AM(UTC)
mavik
Not only for FX also for cropping resizing etc.
Pro:
No waste of resources
If you use the same input in different layer configs or such. If you change the original the virtual inputs follow. So no additioanl changes.
Con:
More confusing
TL68 on 3/16/2026(UTC)
Guest (5)
