Riddlez
#1 Posted : Saturday, May 29, 2021 1:00:58 PM(UTC)
Riddlez
Hi everyone.
I'm trying to create a timer that only displays the timer/countdown in seconds. Is this possible?
I see that the Display Format allows you to add the timer as HH:mm, HH:mm:ss, ss and a few others. But I'd love it to be "ssss" as I need to display seconds from 0 to 5000 continuously
Can this be done, through countdown or with scripts?
#2 Posted : Saturday, May 29, 2021 4:43:48 PM(UTC)
Time formats follow the normal time rules
Script will do that for you
https://www.google.com/s...wAhUKahQKHYmcBoYQ4dUDCA4
Peter1000
#3 Posted : Saturday, May 29, 2021 5:40:46 PM(UTC)
Peter1000
Switzerland
Was thanked: 88 time(s) in 68 post(s)
if you only want to display seconds, counting up, there is a very simple solution
make a new script
copy this in:
Code:
dim second as integer =0
do while true
API.Function("SetText",Input:="Title 0- The Classic Blue.gtzip",SelectedIndex:="1" ,Value:=second)
second = second + 1
sleep (1000)
loop
load the Title Title 0- The Classic Blue.gtzip from the predefined Titles.
start the script
the script passes the value to the Title and puts it in the first field.
to stop or reset the time, some coding is needed again.
To implement more complex time displays, follow the link in doggy's post.
Riddlez
#4 Posted : Saturday, May 29, 2021 6:00:12 PM(UTC)
Riddlez
Cheers that makes sense. Thanks for your help Doggy your help is much appreciated!
#5 Posted : Saturday, May 29, 2021 6:49:17 PM(UTC)
As peter1000's answer is the basic way to go , but if you want to play with date/time data and some formatting (not just for counting up seconds) ;-)
Code:
dim StartTime as DateTime
Dim ts As TimeSpan
Dim NowTime As DateTime
do while true
  StartTime = DateTime.Now()
  dim total as integer = 0
  do while total < 10
    NowTime = DateTime.Now()
    ts = NowTime.Subtract(StartTime)
    total = ((ts.Hours * 60) + ts.Minutes) * 60 + ts.Seconds
    API.Function("SetText",Input:="sometitle.gtzip",SelectedName:="Headline.Text",Value:=string.Format("T:{0,4}",total))
    'console.writeline((string.Format("T:{0,4}", total)))
    sleep(1000)
  Loop
Loop
#6 Posted : Saturday, May 29, 2021 7:01:48 PM(UTC)
Code:
API.Function("SetText",Input:="greenmod.gtzip",SelectedName:="Headline.Text",Value:="0")
Do while true
sleep(1000)
API.Function("SetText",Input:="greenmod.gtzip",SelectedName:="Headline.Text",Value:="+=1")
Loop
Ario on 3/3/2026(UTC)
Ario
#7 Posted : Tuesday, March 3, 2026 6:20:02 PM(UTC)
Ario
Was thanked: 20 time(s) in 17 post(s)
I modified the script that was posted just above, so that it used tenths of a second;
API.Function("SetText",Input:="timecode.gtzip",SelectedName:="Headline.Text",Value:="0,0")
Do while true
sleep(100)
API.Function("SetText",Input:="timecode.gtzip",SelectedName:="Headline.Text",Value:="+=0,1")
Loop
It does run.
However, the timing is not accurate.
After about 5 minutes, the time indicated in the vMix title is 3 seconds behind. (checked with the stopwatch on my phone)
Not much else was running on the machine.
Maybe the script does produce accurate timing for full seconds, I did not test this (we need the decimals).
We'll look at a different solution.
First idea is using a URL as a vMix input, e.g. https://www.estopwatch.net
#8 Posted : Tuesday, March 3, 2026 7:17:18 PM(UTC)
Do while true
sleep(100)
Loop
It does run.
You need to use a correct reference time and not just hoping a counting up will be accurate over time hence the use of DATETIME for example
