Record Zoom with Multicorder
Hi, apologies if this has been answered somewhere, I did search Google, the manual, and these forums first. I'm using Vmix 29 with the Zoom integration. I have 4 speakers as 4 inputs, but the multicorder doesn't allow those zoom inputs to be selected to record. Is there a way to ISO record when using the Zoom integration inputs? Thank you
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
Originally Posted by: stranddoctor  Hi, apologies if this has been answered somewhere, I did search Google, the manual, and these forums first. I'm using Vmix 29 with the Zoom integration. I have 4 speakers as 4 inputs, but the multicorder doesn't allow those zoom inputs to be selected to record. Is there a way to ISO record when using the Zoom integration inputs? Thank you Only by assigning Zoom inputs to outputs and recording the outputs in Multicorder.
Thanks, thought that may be the case.
Joined: 7/4/2021(UTC) Posts: 430  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
As I've pointed out before, 4K = 4x 1080p.
Pro can do 8K.
