giulliu
#1 Posted : Wednesday, February 25, 2026 9:09:25 AM(UTC)
giulliu
Hello to everyone
in some situation I had the need to show the remaining time of a List Input to a anchor.
When the List Input is on program, I capture the lower part with the counter and put in the anchor monitor with overlay. It' easy.
When the List is on 2box or other graphics arrangement, this counter bar don't appear.
For this are necessary to put the List input on preview, also for myself, to know the remaining time. But at the last seconds it's needed to put on preview the correct input to switch on program...these create confusion.
With the help of Gemini we are made a simple Python app that read all the files present on a List input and calculated the remaining time, pubblic it on a text input.
Now it's possile to overlay it on a anchor monitor and can read also from director.
I hope this little app can be help you on some circunstance like mine.
vMixTimingPro
This app are made with Python 3.12.10 that need to be installed on the pc that running this app.
On the Settings Tab you can put the IP and Port of vMix sesion, the Name of the list Input to check and the Title Input and Title Field to write the contdown data.
Running screenshot
Have a good day, Giulliu
Kotin
#2 Posted : Friday, May 15, 2026 7:07:04 AM(UTC)
Kotin
Thanks for the implementation and the idea! It can really be useful. But, scripts in vmix allow you to retrieve this data, although you need skills and understanding in writing scripts in vmix.
Ai helps out)
